Main vent ID
kcopp
Member Posts: 4,630
Any one out there ID this main vent? Please. Went look at a very large system and they had replaced these w little Ventrite # 35’s .. I need to replace w something more appropriate. Picture was from the Land lord. Lok similar to Hoffman 75/77... Ty, kcopp
That vent looks to be mounted on its side. If so, it wouldn't work under any circumstance. They need to be mounted vertically.
In any case, it is not a Hoffman 75/77. There are much better venting options available for larger mains, like the Barnes and Jones BigMouth, available at Supplyhouse . com, link below.
https://www.supplyhouse.com/sh/control/search/~SEARCH_STRING=Bigmouth vent?searchText=Bigmouth+vent
Is this a one pipe or two pipe system? That may impact where the vents should be installed.
Single pipe system. The other contractor pulled out and tossed the old vents.
A big mouth is prob best then. Just wanted a comparison as the original folks knew better.0 -
Vent size wasn't as critical back when the system was originally installed. They were coal fired and typically ran, at various firing rates, from the first cold day until the next spring. Once the air was out of the system, at the first firing, there was little to no air to remove after that, except where a boiler might have been allowed to run out of fuel.kcopp said:Single pipe system. The other contractor pulled out and tossed the old vents.
Not the case today, with all the cycling. Air needs to be expelled multiple times a day. The faster/higher capacity main vents are the most effective.0
