Installing check valves in a two zone system.
JackW
JackW Member Posts: 236
I am redoing my radiant heating system in my Morton building, all piping is 3/4". It is a two zone system, each zone is controlled by a pump. In the old setup I kept the temperature in zone 2 higher and never had to set the thermostat in zone 1 because the zone 2 pump would pull water past the zone 1 pump heating zone 1, not as warm as zone 2 but ok. I want to put check valves ahead of the pumps to prevent this parasitic draw but I'm afraid the 3/4" check valves will restrict the flow. When in the open position the stopper hangs partially down which I would think would restrict the water flow. Is this a concern or not? Any thoughts on this will be greatly appreciated.
Thanks,
Jack
  • Zman
    Zman Member Posts: 7,614
    Unless your pump sizing is marginal, the addition of the check should not be an issue.
    Albert Einstein
    JackW
  • JackW
    Good to know, thank you for your response.
  • Simply Rad
    Simply Rad Member Posts: 209
    Grundfos 3 speed pumps come with integral check valves
    Jeffrey Campbell
    JackW
  • JackW
    Thanks Simply Rad I'll look into that.
