Peerless Boiler, Buzzing from Gas Valve
jch1
jch1 Member Posts: 200
Hi all, I just fired up the Peerless Model 63 this morning for the first time this season (after flushing water a few times and adding two steamaster tablets). All appeared to be going well until I suddenly heard a very loud buzzing. I determined that the sound seems to be coming from the gas valve, since it changes pitch and volume when i push on it. I turned the thermostat off several times and restarted it, and the sound came back each time - I read that they sometimes "correct" themselves after a while.
I have a guy coming out on Monday, but here's the interesting thing. I had the system off all day, and decided to turn it on about an hour ago. There was no sound at all initially, so I followed the steam as it went around the one-pipe system. Shortly after reaching the vents (i.e., the end of the run), it began to buzz/vibrate. Could it be vibrating due to the system building up pressure? I'm hoping I just need the gas valve to be replaced, which looks to be about $100 in parts. Should I be concerned about something else?
  • Fred
    Fred Member Posts: 8,542
    @jch1 , most likely the gas valve or a transformer.
  • jch1
    Thanks, @Fred - I'll just suggest they replace that and hopefully that's all I need.
    Would it be unwise to run the system with it in its current state?
    HVACNUT Member Posts: 7,232
    It would be unwise for anyone here to answer that question with such limited information.
    Shut it down and wait for the Pro. BTW, the prices you find on a Google Search dont reflect the contractors overhead.
    jch1
  • mikeg2015
    mikeg2015 Member Posts: 1,194
    If it only buzzes when firing, probably the coil on the gas valve. Is it going ot fail? Hard ot say. My previous boiler buzzed for 2 winters before I changed to a 2 stage setup. That valve was 35 years old original. The buzz I think is jus the steel core (made of a stack of thin stampings) has started ot come loose inside the copper winding. I think there’s usually a plastic pacer in there, but eventually the vibration will cause a short in the copper windings and it’s done.
