Our skim port pipe plug is too tight...
We turned on our boiler last night and noticed the skim port pipe plug on the end was too tight to remove using our 2 pipe wrenches as usual. We wanted to lower the water in the boiler to do a cold skim by dropping the water level down from summer storage that was a few inches above the skim port, and in a few weeks we'd like to skim it and might add another steamaster tablet into the port. Do you recommend using a liquid wrench spray to loosen the threads on the plug so our wrenches can get it off, or another method for ease of removal ocassionally?
    ethicalpaul Member Posts: 8,167
    edited October 2019
    Definitely try something like PB Blaster, sure, there's nothing to lose. An impact wrench can work great too. Curious, did you have teflon tape on the plug or is it metal to metal?
    Oh and for additional ease, I installed a ball valve on my skim pipe
  • JUGHNE
    JUGHNE Member Posts: 11,513
    PB Blaster or Kroil spray, let soak, firm tapping with hammer on the plug and fitting. Spray again, hammer again.
    Then a 2-3" long nipple and cap is a much better choice for future removal.
  • SeanBeans
    SeanBeans Member Posts: 525
    Bigger wrenches!
  • JUGHNE
    If the square end of the plug is snapped off then that is bad.
    This I do know about. :s
  • cubicacres
    cubicacres Member Posts: 360
    edited October 2019
    Thanks. We put Teflon tape on due to drips last season per the photo. Installers used a gate valve. Seems like it either drips a bit or is too tight 😊
  • ChrisJ
    ChrisJ Member Posts: 17,070
    What size wrench are you using to try and remove it?
  • cubicacres
    2 good sized pipe wrenches, with one cheater/extender working on cap square, but we didn't want to break anything with too much force. I think 2.5 inch max & 3.5 inch max for the jaws of the pipe wrenches, about 1 inch square pipe cap on the end, so fits fine around it in the jaws.
  • BobC
    BobC Member Posts: 5,539
    When you do get that plug out replace it with a brass plug, they don't cost all that much.
    Bob
    3PSI gauge
  • ChrisJ
    If I was having trouble, I'd use two 24" pipe wrenches and honestly I can't see how those wouldn't make that plug turn especially in a brass fitting.
    SeanBeans
  • Motorapido
    Motorapido Member Posts: 314
    I find it helps if you heat around the exposed threads before applying kroil or pbblaster. The downside is that this creates a steam cloud of the penetrating oil, which smells very strong, but many believe that this encourages the penetrant to go deeper into the threads. Be ready for stink.
  • cubicacres
    Thanks for the advice. Maybe a brass plug without the teflon tape will work better once we get it off. I saw this youtube video comparing penetrating oils while ding my research yeserday, and noticed heating it works best, followed by cheaper oils per his test, but they were similar overall:
    https://www.youtube.com/watch?v=xUEob2oAKVs
  • cubicacres
    Just curious Bob/Chris/anyone, why is a brass plug easier to remove compared to our current steel one? I'd imagine we could bend/misshape it more if we pull on it with enough force compared to the steel one. And swapping the gate valve for a ball valve-do ball valves tend to resist drips/leaks better in a skim tapping setup like ours?
  • ChrisJ
    I don't see the point in the valve honestly.
    I had a ball valve and over time it was ruined so I removed it and replaced it with a brass coupler and brass plug.
    The reason for all brass is it doesn't rust.
  • cubicacres
    Since the gate valve still allows some water to drip out when the boiler is running, maybe the valve isn't needed and just go with a brass plug? Any difference between a cored brass or non-cored brass plug for this use?
  • BobC
    I've had a ball valve on my skim port for 7 years and it does not leak. My brass 1-1/4" plug is solid not cored, I ordered it online from supplyhouse.com and don't remember being offered a choice.
    Bob
    3PSI gauge
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,578
    You are better off with a nipple and cap, Which is more easily removable, instead of a plug.—NBC
    JUGHNE
  • cubicacres
    They just had one type of brass cored 1.5 inch cap locally, so we bought that for now. For future reference, does a cap loosen & tighten with pipe wrenches similar to a plug, but on the outside of the end of the nipple, not the inside like a plug usually does?
  • Fred
    Fred Member Posts: 8,542
    Yep, one wrench on the cap and the other wrench on the nipple to keep it from turning.
  • ChrisJ
    edited October 2019
    I don't know what kind of pressure you're running, but my brass plug and brass coupler are little more than hand tight. As in screw the plug in by hand as tight as I can and then give it a little more with a wrench. Certainly not near enough tight to need a second wrench on the coupler to keep it from turning.
    It doesn't leak so I don't mess with it. But I've also found brass seems much easier to get to seal than steel.
  • cubicacres
    We're usually between 1-3 psi. With the drips after the gate valve we noticed, we used teflon tape & tightned it pretty well, so we'll try the brass plug we have and see if we can get by with less tightening.
