First time seeing one of these.
Double D
Member Posts: 449
They're on every radiator. I didn't run the system because the boiler needs to be replaced. 9 of the radiators out of the 13 have regular air vents. The other 4 only have the what is in the pictures. Do I need to remove them and put a standard plug in or can I just put JB weld over the holes and put radiator air vents on the remaining 4?
Those are Ideal "In-Airid" vents. I wouldn't JB-Weld them- remove them and plug the openings if they need replacing. They come out easily with an impact wrench.All Steamed Up, Inc.
Consulting0 -
I would clean them out with a paperclip and see if they still work first.0
If they work leave them in.gwgillplumbingandheating.com
At one time these used to vent the radiators? Cleaning may work for some but half of them have been drilled plus a vent was added.0
Wouldn't those have been used back when the system was coal or wood fired because of the vacuum. With a modern oil fired boiler I think you would want a non-vacuum vent valve since it's pretty much a steady constant heat source.
I may be wrong as I'm not an expert but I thought I remembered reading about that.0 -
If you can keep the system in vacuum more of the time the boiler will steam earlier and longer at a lower temp transferring more of the heat from the fuel to the structure rather than up the flue.0
Thanks @Steamhead the impact driver works great. I have no choice but to at least remove the ones that have been drilled.0
- 428 Carbon Monoxide Awareness
- 114 Geothermal
