Shutoff Valve Needed for 1 Pipe Steam?
I have a one pipe steam system.
I’m replacing some baseboard and freestanding radiators with Sunrad recessed radiatiors. The plumber installed the new radiators without a shutoff valve. Is this an issue? In theory if I needed to shut off the radiator I could block the vent, but just seems strange that they were installed without shutoff valves and want to make sure I’m not going to have an issue down the road.
  • JohnNY
    JohnNY Member Posts: 3,380
    Your plumber should know better than to install heat emitters of any kind without shutoff valves.
    Consulting & Troubleshooting
    Heating in NYC or NJ.
    Classes
    Agreed. Granted, however, that they are not used for control on one pipe steam -- that's what the vents are for. But they sure should have been installed.
  • STEAM DOCTOR
    STEAM DOCTOR Member Posts: 2,617
    Just to play devils advocate. One pipe shutoff valves are almost never used. There is a good possibility that they will leak at some point. They also restrict flow. If I was building a single family residence with one pipe steam, I would seriously consider eliminating radiator shutoff valves.
  • JUGHNE
    JUGHNE Member Posts: 11,591
    I agree with Steam Doctor for the most part.
    But the angle valve gives you a compact 90 connection with needed union.
  • STEAM DOCTOR
    You could get a radiator union elbow.
    JUGHNE
