Backflow & check valves needed with boiler on private well.
OhioRuss
Member Posts: 29
I live in a rural area with private well and septic system. I’m installing the Lochinvar combi with Alpha 2 pump to distribution manifold to cast iron radiators. I intend on using Califfe’s water treatment cartridge. Are backflow and checkvalves needed? Thanks. I truly appreciate all the shared wisdom
whether it's code there or not,
that or an isolated make up water system,
definitely protect your well and domestic water.
known to beat dead horses0 -
A simple dual check with a vent is pretty inexpensive. You really don't want nasty boiler water in your drinking water."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
- 129 Chimneys & Flues
- 127 Geothermal
