Help with Piping Pensotti Radiator Diagram Attached
ced48
ced48 Member Posts: 469
edited August 2019 in THE MAIN WALL
I am trying to substitute 17' of baseboard with a Pensotti flat panel radiator. Just not sure how to do this without upsetting the balance of split loop system shown in the enclosed diagram.. Any suggestions, thoughts, would be helpful.
  • Solid_Fuel_Man
    What are your connection sizes for the panel rad?
    Assuming what you have now (piping and fin tube) is all 3/4" copper?
    You may be able to do a venturi T to the new rad.
  • ced48
    edited August 2019
    !/2" connection for the radiator, 3/4" fin tube. Penscotti offers a bypass valve, which can be adjusted.
    hot_rod Member Posts: 28,250
    typically no more than 3 panel rads in series, with those bypass H valves Unless is upsize the rads on the tail end of a larger series You can calculate temperature drop thru a series of emitters
    Splitting the loop would avoid an excessive delta
  • ced48
    edited August 2019
    Because it would be the first emitter in the series, what would happen if it was piped direct? I am not sure how to figure pressure drop for the unit, so there in lies my confusion.
