Radiant setup for fully poured concrete home
2»
    hot_rod Member Posts: 27,826
    You could add 30 feet or so without too much of an issue. Installers that buy 1000' rolls often cut it into three 333' loops :)
    A 300' loop at .5 gpm is just under 3'head, a 330' just over 3'. from the RadPad quick calc.
    Be sure the plywood fasteners catch those aluminum plates so they don't move around and squeak.
  • John Ruhnke
    John Ruhnke Member Posts: 1,020
    Plates when not properly fastened can make noise when the tubing expands and contracts. I used to install systems and re pipe other peoples problem systems. So I have heard a few noisy plate jobs. We always follow the manufacturers specifications attaching the plates for that reason. Laying down plates loose like that could be a problem.
    I am the walking Deadman
    Hydronics Designer
    Hydronics is the most comfortable and energy efficient HVAC system.
