Munchkin Replacement
We replaced this 15 year old Munchkin boiler yesterday. It was at the far end of a 42” crawl space. At least it had a rat slab. We laid down a foam walkway to crawl on but it was still no fun.
  • Dan Foley
    Dan Foley Posts: 1,268
    We went back with an NTI LX because it is short, floor mounted and the controls are accessed through the front.
    We cleaned up the Pex piping as best we could. The 45 gal. Indirect was replaced with a 65 gal NTI. The owners complained of running out if DHW. This was the biggest tank that would fit in a tight closet.
    IronmanGroundUpSolid_Fuel_Man
  • Dan Foley
    The existing DHW tank did not have a T&P. Someone installed a black cap instead. It had pinholes and was leaking. There was not much metal left when we removed it. It was almost ready to let go.
  • RayWohlfarth
    RayWohlfarth Posts: 2,076
    @Dan Foley Nice looking job considering what you inherited You needed 4 foot tall installers
    Ray Wohlfarth
    Boiler Lessons
    Dan Foley
    HVACNUT Posts: 7,656
    Beautiful! Love the cabinet for the circs and zone board.
    Dan FoleyCanucker
    EBEBRATT-Ed Posts: 20,946
    I guess the original installer new the inspector (if he even got a permit) wasn't going in their.
    Nice job!!
    Dan Foley
  • Great job. Hope the customer understands the quality of work you gave them compared to what they had.
    Never stop learning.
    Dan Foley
  • Dan Foley
    @ HVACNUT
    The pump panel is by HPS Controls
    We used it to speed up the install. Field piping a pump panel in a tight crawl hole is not ideal.
    GroundUp
  • JUGHNE
    JUGHNE Posts: 11,633
    Grand improvement.
    Who said that lipstick doesn't work. ;)
    We have all known home owners who do not want any equipment visible or do not want to lose closet space. Then in a few years they cry tears because no one wants to work on their stuff.
    They should be grateful to you for what you did....a good tip is in order I think.....bill accordingly.
    Isn't there any code that requires equipment as such to have a minimum ceiling height? Circuit breaker boxes need 6 or 6 1/2 feet of ceiling height. I learned this the hard way BTW.
    IronmanDan Foley
  • Ironman
    Ironman Posts: 7,942
    Beautiful work.
    I thought I was the only one that got to go behind those hack jobs in crawl spaces.
    Bob Boan
    Dan Foley
  • GroundUp
    GroundUp Posts: 2,547
    Awesome job you guys do! They sure are proud of those HPS panels $$$ but dang are they nice!
    Dan Foley
  • Solid_Fuel_Man
    Solid_Fuel_Man Posts: 2,644
    Crawling in a crawl space! Definatly a vast improvement, and nice to be able to press copper down there too.
    My BIL has a home on a similar crawl space with spaghetti PEX and a combi in it. I was tempted to shark bite it all!
    Dan Foley
  • Paul Pollets
    Paul Pollets Posts: 3,672
    Nice job in a difficult space. I'm always amazed by the poor workmanship in these types of jobs. Encouraging to see such good work!
    Dan Foley
  • archibald tuttle
    archibald tuttle Posts: 1,199
    edited July 2019
    well a black cap with pinholes is kind of like a T&P . . . no? :D
    Dan FoleyAlan (California Radiant) ForbesCanucker
  • ScottSecor
    ScottSecor Posts: 1,055
    Beautiful job as usual Dan. You and your crew earned whatever money you made on this job. My knees hurt just thinking about that crawl space.
    Trying to stay positive here, whoever installed the Munchkin at least insulated the pex tubing. Just curious, did the Munchkin fail?
    Dan Foley
  • archibald tuttle
    edited July 2019
    nice indeed. gotta love crawl spaces. and cpvc better than previous by a long shot albeit although still theoretically non-conforming by stack temp if you are running indirect hot water which is looking for 180 degree boiler water temp and has relatively hot return.
    when i go back to these jobs, if it is remotely possible, i'm switching to on demand condensing hot water to get the stack temps down in the boiler and in the water heater and working with emitters for as low a design temp as possible.
    I've had incredibly trouble free operation with the non-condensing on demands in place for like 15 years without trouble. Don't know if the condensing units will last as long but I'm stoked with stack temps all around.
    not criticizing, you play the hand you are dealt and left it way better than it was.
    I have found that the System 636 has the DWV style 90 in CPVC. It isn't really a sweep el as they claim, but it is by comparison to those those blunt standard CPVC turns - which i don't even like for pipe friction with fluid flow - although with the higher unit in the crawl space you might have been limited. i wish they would make the DWV pattern 45s in CPVC as well.
    Definitely like the crawl path! Save the knees for the next job.
    Dan Foley
  • Good grief! The before pics certainly illustrate what a nightmare your crew had to deal with. Outstanding completion!
    Dan Foley
    hot_rod Posts: 28,204
    Dan, a dual check, no vent accepted on the boiler fill?
    Certainly solves the dripping issue if code accepts it.
  • Dan Foley
    Hi HR,
    Technically thus would not pass code. 1. It is unlikely the inspector is going to crawl 30’ across this crawl space to check. 2. There is no floor drain. No one will notice the backflow is leaking until it floods the space.
