You Just Can't Beat a Good Hack
Ironman
Member Posts: 7,376
Changing out this boiler which was connected to a monoflo system with TRVs on the rad's. The hack who installed it connected the return to the supply and vice versa. Notice the flow check which was connected to the pump on the return.
Bob Boan
Well, at least he knew to open the flo-check so the water could move...........All Steamed Up, Inc.
Consulting0 -
He also vented it into a 100 year old unlined chimney.Bob Boan
What are you putting in?All Steamed Up, Inc.
Consulting0 -
I've got an almost new Ultra (not my favorite by any means) that we removed from another job a few months ago. We're also installing a commercial indirect, so the chimney will be abandoned.
It's an old, large house that a college had used as an admin building but is now being turned into a dorm.Bob Boan
@Steamhead
You'd love this job. It was originally a two pipe steam system which someone converted to a monoflo before the hack that did this boiler about 15 years ago.Bob Boan
You can choose to do what you want, but you cannot choose the consequences.1
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
