How does air affect efficiency?
Trum
Member Posts: 5
in Oil Heating
Does air in hot water baseboard piping affect heating efficiency?
Yes.
Basically if there is air in the system, the system isn’t delivering all the btus into the home it’s making. So the boiler will run longer then needed to satisfy the call for heat, bouncing off the high limit and cycling.There was an error rendering this rich post.
- 125 Chimneys & Flues
