Steam Separator
STEAM DOCTOR
STEAM DOCTOR Member Posts: 2,506
edited May 2019 in Strictly Steam
Steam travels from boiler to separator through pipe on bottom,left of separator. Steam makes right turn and moves toward pipe on right side. Condensate drops out through pipe on bottom right into return. Steam makes u-turn and enters system through pipe on top left of separator.
  • RayWohlfarth
    RayWohlfarth Member Posts: 1,893
    Looks like it could work. Is there a horizontal plate in there? I like that there is no offset in the vertical piping
    Ray Wohlfarth
    Boiler Lessons
  • STEAM DOCTOR
    Yes. There is a horizontal plate. Removed from 90 yr old boiler
    EBEBRATT-Ed Member Posts: 19,477
    Reminds me of the old HB Smith boiler with the built in cast iron header. I had worked on them for years before a factory guy told me the cast iron header had a plate inside it to separate the water and the steam.
    Should work well
    Jamie Hall Member Posts: 26,807
    Hmmm... your comment @EBEBRATT-Ed , makes me wonder if there is such a plate in the cast iron header ("steam drum") which we saved when we installed Cedric. Whatever, between that and the drop header the steam is pretty dry!
    In any event, nothing like a sharp U turn to run the idiots (water drops) off into the weeds (and down that pipe), while the steam merrily drifts around... >:) (been watching too many rallye videos on YouTube!).
    @Jamie Hall
    I never saw the baffle but someone from Smith told me they were in their when the boiler was ordered for steam. We had one job we were having problems with and he asked me if the baffle had fallen down inside the header. "what baffle" I said. That's how I found out. I guess they slide in through the big threaded plug in the end of the header.
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,682
    This sure looks like the work of the late, great Frank Gerety.
    Retired and loving it.
