Swimming Pool Cooling
I have a 1400 gallon hot tub heated to 106F with a boiler and HX. There is also a 1000 gallon "Dip Pool" that need to be maintained to 45F all year round. The dip pool has no heater only a filter system.
I'm looking for some kind of a chiller/heat system to maintain this dip pool 45F all year round.
Yes the pools are covered, outdoors.
  • Andy_d
    Andy_d Member Posts: 10
    This is located in Whistler British Columbia. Groundwater temperature is about 40F
    EBEBRATT-Ed Member Posts: 20,615
    I would check into a water-water heat pump. You may need a heat xchanger to deal with the pool chemicals.
    hot_rod Member Posts: 27,957
    Perhaps the noise would be an issue? Any of the air to water HPs would work. It might be cheaper to heat with also?
  • Andy_d
    Thank you for your input, I'm going to check out both systems.
  • mikeg2015
    mikeg2015 Member Posts: 1,194
    R410a Water to water geo unit will work if you have low approach heat exchangers. chiller would work. Can make 120-130F hot water to heat the tub and simultaneously make about 35-38F chilled water for the dip pool using heat exchangers on both. A gas fired small mod-con can add heat to the return water off dip pool @ 99% efficiency if the imbalance is in heating. IF the imbanace is cooling load, then you can have a air to water heat exchanger blow heat outdoors. You’d want propylene glycol to be safe on this system.
    Will want a storage tank on both sides with loop pumps and chiller pumps.
    Keep in mind you dip tank loading will be very dynamic. They don’t have a lot of mass, so you may need that heat exchanger oversized. Have to run numbers. Hot tub is more of a constant steady load so don’t need as much storage nessesarily.
    The controls can be simple but may need to play with differentials and temperatures to get it all running efficiently.
