Does It Matter Where You Place The Thermostat?
HeatingHelp
Administrator Posts: 715
He pointed to the five thermostats mounted on the wall next to the cash register. "Seventy degrees," he said, and I started to giggle because this was the first time I'd noticed that all his thermostats were behind the cash register. No wonder the place felt like a coal mine.
Told only the way you can tell it Dan!! Sounds like on of my dates:)
I don't get it. If the stats are near the door where it's cold the they will be calling for heat. The place will be to hot!!?0
I don’t get it either, Dan. If the thermostats are near the door and getting shots of cold air, it seems that would overheat the place rather than leave it cold. Unless the cash register is putting out heat keeping the thermostats warm. Need more information hear as something seems odd at first blush.0
Love the Story, but west bye has it right, the thermostat by the front door would turn ON the heat overtime the door was opened, resulting in overheated spaces.0
If you reread the 3rd paragraph, you'll see the story takes place on a hot and humid night in August. So the stats by the door kept getting shots of hot and humid air when the door opened, therefore running Cool in the already cold diner.
Yes, remote sensors would be a good idea. Then only Gus touch! and the diner would be more comfortable.
I love rereading Dan's stuff. Been doing it for years.0 -
Ah, yes, that would do it!0
It was a hot August night, opening door caused AC to keep coming on0
Somebody missed reading the key words to this funny human nature story.
"It was a hot AUGUST night"
Great story! Dan could have supported
The family simply on his literary skills.
Thanks. Yes, it was summer. And I wrote that one about 25 years ago.Retired and loving it.0
I have found thermostats installed in direct sun light, on outside walls, in closets, in front of windows in direct sun light, on mirrors ,and in direct heated reflection of mirrors, and directly over radiators.
The complaint has always been, "It's never comfortable in here."😊❄️🔥0 -
I remember the fundamental theorem of thermostats, as explained to me by the best engineer I ever knew. It goes:
A thermostat acts to keep itself comfortable.
So if you want to be comfortable too, put it near where you will be.
My grandfather had an interesting thermostat installed in his house along with a new GE residential oil burning steam boiler in about 1945. It had two dials and a clock. It would keep the white dial temperature in the daytime and the black dial temperature in the nighttime. But it came with a little cover over each so you could not adjust them unless you removed the little covers, and it took a screw driver to do that.0 -
LOL!0
This was one of my favorites . We used to get PM magazine at the shop back in the day , the boss nailed a scrap piece of sheet metal above the thermostat in the shop that said " Only Gus Touch !!! ". And of course the sign became a forum for some negative statements about Gus , lol.hvacfreak
Mechanical Enthusiast
Burnham MST 396 , 60 oz gauge , Tigerloop , Firomatic Check Valve , Mcdonnell Miller 67 lwco , Danfoss RA2k TRV'sEasyio FG20 Controller
LOL! Thanks.Retired and loving it.0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
