Pitching Sagging Center Radiator
ksd99
Member Posts: 77
I understand how to pitch the vent end of a radiator but how do you pitch the center?
New owner of 1 Pipe Steam Boiler - learning all I can- no real steam pro in S.W. Michigan - if you know of 1 -let me know.
Say again? If this is a conventional radiator -- big cast iron thing with four feet, or it it's really long, six feet (two in the centre), if it's sagging in the middle it's coming apart. And will probably leak, if it hasn't already started...Br. Jamie, osb
If it's working properly, leave it alone.All Steamed Up, Inc.
Consulting1
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
