Help identify this valve?
Does anyone know who the manufacturer of this valve is?
While I would normally replace a valve, these valves have built-in cabinets around them, and it would be a big project to try to get them out. Hopefully, I can get replacement parts.
The problem is that the valves do not close, and we would like to shut these off.
Thanks for your help.
  • It says Milwaukee Valve Co.
    If you take it apart, it may be a generic part that can be replaced.
  • Ironman
    Ironman Member Posts: 7,857
    Is it a one or two pipe system? If it's a one pipe, just turn the vent up side down and that will turn the rad off.
    Bob Boan
  • rhodebump
    rhodebump Member Posts: 155
    It's a 2 pipe system. Thanks
  • Ironman
    What if you first loosen the unions and pull the rad out? You should then have much better access to the valve.
    Bob Boan
  • rhodebump
    the steam trap on the other end cannot be removed since it's too close to the built in cabinet. I didn't want to move the rad too much and end up with a leak without being prepped for it.
    I am going to try just disassembling the valve and see if there is some debris in the bottom that is preventing it from closing.
    Thanks.
  • Ironman
    No union on the trap?
    Bob Boan
