Want to Replace Steam Radiators and Pipes with new Steam Wall Radiators
No personal experience, but I've heard good things of New England Steamworks out of Providence I think. I've had Daniel E. Cadotte Plumbing and Heating on the north shore clean my residential steam boiler and liked him. I believe he does installs and repiping too.New owner of a 1920s home with steam heat north of Boston.
Just trying to learn what I can do myself and what I just shouldn't touch1 -
Talk to Ryan at @New England SteamWorks . Absolutely top notch, works the Boston area all the time.Br. Jamie, osb
@New England SteamWorks was at my place on Wednesday. Can't say enough good things about their work. I recommend them to all my neighboring condo associations. My system has never worked better.1
Agree, @New England SteamWorks is your man! He may tell you to save some money and not replace the existing radiators because, there may be are other issues that keep them from putting out heat. Whatever it is, he can fix it.1
I agree with the above, and especially Fred.
I am sure the radiators and system need some TLC, and can work better than ever with his attention.—NBC0 -
Radiators do not wear out until they leak, IMO.
Same with steam mains....unless buried in concrete.
New England Steamworks would be your gain...……….
......but the rest of us don't get to ask for pictures to ogle over0 -
Jamie Hall said:Talk to Ryan at @New England SteamWorks . Absolutely top notch, works the Boston area all the time.
gfrbrookline said:@New England SteamWorks was at my place on Wednesday. Can't say enough good things about their work. I recommend them to all my neighboring condo associations. My system has never worked better.
Fred said:Agree, @New England SteamWorks is your man! He may tell you to save some money and not replace the existing radiators because, there may be are other issues that keep them from putting out heat. Whatever it is, he can fix it.
JUGHNE said:Radiators do not wear out until they leak, IMO.
......but the rest of us don't get to ask for pictures to ogle overAll Steamed Up, Inc.
Consulting0 -
Thanks everyone for your advise. I have people wanting to replace with gas systems, you name it...all are getting expensive. I just want to replace the pipes that keep leaking in the church with something newer.0
Can you describe which pipes these are?
There are so few techs now who can be bothered to analyze a system and it’s problems in order to find a solution!
Did you mention your location?
Luckily the right ones are on this site, giving their free advice, in order to be helpful.—NBC0 -
If it's just replacing leaking pipes... no need to replace anything else (you mentioned radiators in the subject, for instance), I still think @New England SteamWorks would be a good resource. That particular job really isn't that hard for someone who actually isn't afraid to thread iron pipe -- although sometimes it does require care to maintain proper sizes and pitches.URCC said:Thanks everyone for your advise. I have people wanting to replace with gas systems, you name it...all are getting expensive. I just want to replace the pipes that keep leaking in the church with something newer.
The church is built on a slab, with the 3" main buried in concrete under the raised pulpit and floor. It's under-radiated, but the main issue is that the main(s) need to be jack hammered up and replaced. The boiler died a premature death from all the freshwater. Vents and traps need help.
All in a day's work...New England SteamWorks
newenglandsteamworks.com0 -
Another job well done by a reincarnated dead man of steam!0
- 84.3K THE MAIN WALL
- 53 Biomass
- 417 Carbon Monoxide Awareness
- 44 Chimneys & Flues
- 1.8K Domestic Hot Water
- 4.8K Gas Heating
- 120 Geothermal
- 156 Indoor-Air Quality
- 3K Oil Heating
- 57 Pipe Deterioration
- 797 Plumbing
- 5.4K Radiant Heating
- 371 Solar
- 14.1K Strictly Steam
- 3.1K Thermostats and Controls
- 39 Industry Classes
- 80 Job Opportunities
- 22 Recall Announcements
