Can anyone identify this manifold? — needs valve replacements
A customer had this set of roughly 20-year-old manifolds with some valves that leak and some that stick due to broken internal springs. I can find no manufacturer's identification other than the "dual wavy line" emblem shown in the second attached photo. The actuators are Wirsbo but the manifolds are not. Third photo shows the valve I need.
Thanks for any leads on parts.
Sol Brother
  • rick in Alaska
    rick in Alaska Member Posts: 1,524
    I am not positive, but it looks a lot like a Wirsbo truflow manifold, or at least very close resemblance. But from what I can see, the replacement seal looks like it is a little different on the seal end.
    Maybe it is an earlier version of a wirsbo manifold.
    Rick
  • Sol_Brother
    Sol_Brother Member Posts: 34
    Thanks for the response. I sent the photo to a tech at Wirsbo who said it was none of theirs.
    Sol Brother
  • HEATON
    HEATON Member Posts: 121
    Watts radiant?
  • Intplm.
    Intplm. Member Posts: 3,002
    This has become such a big issue.
    I'm wondering why manufacturers do not put the names on there stuff like they used to.
    In the past you couldn't miss who made what. ?
    I do not understand this "trend".
  • Intplm.
    Did Uponor make Wirsbo like Viessmann made pipe in different diameters or (metric) to not match American pipe sizes way back when.
    Could this be a Wirsbo , Uponor thing??
    A manufacturing hiccup?
  • Leonard
    Leonard Member Posts: 903
    edited February 2019
    Likely manufacters are buying "off the shelf" from cheap suppliers and don't want to spend $$ putting their numbers on it. Likely a small company or it would lead to inventory control problems if had many similar parts.
    hot_rod Member Posts: 27,403
    looks like a Sparco logo?
    Steve MinnichZmankcopp
  • Intplm.
    Its' an opportunity lost in advertising. In company recognition.
    The more the product is shown and recognized, the better for the product, the customer, buyer, installer, owner.
    Surely you will agree. ?
    This just seems to contribute to the throw away society.
  • SENWiEco
    SENWiEco Member Posts: 164
    @Sol_Brother - Based on web search looks similar to Mr. Pex and this looks like your part
    Sean Wiens
  • Harold
    Harold Member Posts: 249
    Even more annoying is manufactures not keeping valves for the manifolds in a long term stock. Manifolds are sort of supposed to be forever.
    I have had to replace some manifolds simply because there were no parts available. Installation was about 15 years old. It is a lot of money when only a couple of valves are bad.
  • GroundUp
    GroundUp Member Posts: 2,513
    I've got some Zurn manifolds with the same brass log, but different valves... Also have some Wirsbo that look very similar. Wonder if there was a bulk manufacture of the logs at some point and several companies marketed them as their own with final assembly at their plants?
    IamNotLost
  • Intplm.
    Wow. Is that what it says? Eagle eyes for sure.
    Here is a Honeywell/ Sparco mix valve, look like the same logo?
    Looks close, or a knock-off
  • Sol_Brother
    Good eye, Hot Rod, seeing the match to Sparco's logo. I knew I had seen those SS somewhere.... Thing is, I can't find any evidence that they made manifolds. I wrote a note to Honeywell (who now owns Sparco) but of course, the possibility of finding anyone who knows product history at a huge corporation like that, or even getting a human to respond to an email, is slim. No response from them.
    And to SENWiEco, yes it is very similar to the Mr PEX. I had been convinced it was not theirs because the shaft in the middle looks to be longer on the one I have than on theirs, but maybe I am just being fooled by the photos. I will get a Mr PEX valve in my next Supply House order and give it a try. I have some Wirsbo/Uponor valves which are also very similar but not quite the same.
    Sol Brother
  • Sol_Brother
    Aha, Sparco did make manifolds, but not like this one. Cleaning out an old folder of miscellaneous valve information, I found a brochure that included this photo, obviously different in every way from the one I am dealing with.
    Sol Brother
  • Solid_Fuel_Man
    That Sparco looks like the early 1990s Wisrbo for sure.
  • rwhtg
    rwhtg Member Posts: 34
    I’m pretty sure that is the “modul” brand symbol. I’m searching for info my self.
    Skilled labor isn’t cheap, cheap labor isn’t skilled.
  • rwhtg
    My customer says “cazzinagia”??? Used to be manufacture?? Idk. I can’t find anything online. I want to know if there is a balancing chart for number of turns and GPM.
    Yes a Cazzinagia brand, very similar logo to Sparco.
    You should be able to run it down through a Watts rep, if you can find an old timer that will dig back a few years. All that tech data is still out there.
    Do you know how many gpm each loop requires?
    Open the valve all the way, close the valve all the way and count the turns, set it 1/2 way.
    You would need to wait to heating season, open all of them full and choke down the over heating areas.
    Unless you have a spot on design sheet, the designed gpm flow rates will be a guesstimate at best. Even the best calculated designs sometimes need tweaking to throttle back over performing loops.
    With 1/2 tube generally .50- .65, unless you have some very short loops or rooms with very low heat loss.
  • Sol_Brother
    You guys are a treasure chest of information. Unfortunately I have tried for over a year (intermittently) to get anyone at Watts who will respond as to whether they have parts or not.
    Sol Brother
