Radiator Vents
ksd99
Member Posts: 77
I have Hoffams 1A and Hoffman 40 on my radiators, I know that 1a I can adjust the speed that the steam fills the radiator from 1 to 8, and the Hoffman 40 is a non adjustable speed. Ok my question what setting on the 1a is the same as the 40? I hope that made sense, I am just interested to know.
New owner of 1 Pipe Steam Boiler - learning all I can- no real steam pro in S.W. Michigan - if you know of 1 -let me know.
The 40 is about half way between the 1A on 2 and on 3.Br. Jamie, osb
Thanks Jamie.
New owner of 1 Pipe Steam Boiler - learning all I can- no real steam pro in S.W. Michigan - if you know of 1 -let me know.0 -
The Hoffman 1a is hard yo adjust because of the sloppy fit on the adjustable bonnet, make sure the bonnet is centered or the vent rate can be pretty far off the markings.
3PSI gauge0 -
Thanks Bob.New owner of 1 Pipe Steam Boiler - learning all I can- no real steam pro in S.W. Michigan - if you know of 1 -let me know.0
