VariVent 925005 vs Hoffman 1A Vent for Steam Radiator ADJUSTABLE or any other possibles??
HotnDry
Member Posts: 14
Hey Gang,
Trying to figure out an air vent to screw into the end of a long cast iron baseboard radiator. As with many ancient installations the less you disturb things the fewer reasons you have to cry and this one really screams be careful. I tried a Hoffman 1A but can't swing it without moving the radiator. Went to the InterWeb and found a VariVent 925005. Can't get dimensions online nor at tech support. It looks promisingly compact. Anybody know how big this thing is? The center of the tap to the wall is 1 5/8" to max 1 3/4". Can you turn this thing off like you can a Hoffman 1A? Any other compact low pressure steam vents out there?
Here's what I'm looking for:
1/8" connection
Adjustable - room is overheated
Low Capacity - room is overheated
Swing Dimension of 1 5/8" or maybe 1 3/4" absolute max if angle type
1/8" connection
the maid-o-mist with adjustable orifices is probably the most compact of the bunch and affordable too
https://www.amazon.com/gp/product/B003DV3AGE/ref=ppx_yo_dt_b_asin_title_o02__o00_s00?ie=UTF8&psc=11 -
I don't like either, I recommend Ventrite No. 1's. Much easier to adjust then the Hoffman and not as aggressive as the varivent. Also nice and quiet.0
Vent rites are in my limited experience the best vent. Quiet and cover the ideal range. I just wish they made a vertical version for wall radiators. I might just try installing it on a right angle.0
I've had two bad 1As, can't recommend them. and I'd stay away from Varivents since they do not have any kind of float valve in case the system floods.0
- 119 Geothermal
- 394 Solar
- 15.9K Strictly Steam
- 50 Industry Classes
