Mixing valve
Snowmelt
Member Posts: 1,457
On my radiant floor I have a mixing valve, no water is going thru it. Can I take it off, and soak it under some simple green to clean it, or am I waiting my time?
What kind of mixing valve? How is it piped? What kind of heat transfer fluid?0
Acme mixing, on a boiler. Just mixing down to 120 ....
The line wasn’t warm enough so I went to bleed the air out. The water wouldn’t even push the air out. It was just dead.0 -
Vinegar does work. I have found that it will ,at best, buy you some time before you need to soak it again.
Depending on what type of mixing valve you have, you might be able to rebuild it in place with a "rebuild kit.".0 -
I forgot about rebuilding it, thanks for the little bit of info.
What kind of mixing valve? Acme makes several different models. How is it piped? If you can't push air or water out of a union it's probably got nothing to do with the mixing valve0
I have it set up like are everyday , hot from the supply - cold on the return and mix going up to the pump. I’m almost positive that the valve is. https://www.cashacme.com/product/hg110-hx/0
Sometimes there are screens on the inlets, built into the tailpieces to protect the valve an any checks in the valve. Check them. It would need to be 100% plugged with sludge to not pass any water? as one port closes, the other opens, it can never shut off 100%.
Got enough pump? Be sure it is actually spinning.
Check for strainers in other locationsBob "hot rod" Rohr
Living the hydronic dream0 -
what i did was try to purge the system and only the initial water that was in the return came out ( water from the other zones filling up the air gap, that was it . )
I do have enough pump0 -
Think horses...not zebras.0
- 87.5K THE MAIN WALL
- 123 Chimneys & Flues
- 118 Geothermal
- 15.9K Strictly Steam
- 57 Water Quality
