Adding a Low Pressure Gauge
Can I put a T fitting on the Pressuretrol pigtail and mount a low pressure gauge so the Pressuretrol and gauge share the pigtail? Or is it better to have a separate pigtail for each.
  • neilc
    neilc Member Posts: 3,184
    yes,
    you can,
    it's done all the time.
    The low pressure gage will tell you what the Ptrol is seeing.
    known to beat dead horses
    Jamie Hall Member Posts: 27,379
    Yes. Much the easiest way to do it. There are perfectly valid arguments to be made about the advantages of both approaches -- but for simplicity, the T/single pigtail works just fine.
