Ignition transformer
I have. Franceformer on my AF15 Beckett oil burner . I’m getting smoke drifting up from the air ports on the oil pump side . The entire bottom of the ignition xfmr is wet and also the wiring trough. My question is are the ignition xfmr’s oil filled because all the checking and observation I have done this seems to be the only answer. Thanks for reading
    Some, at least, are. The real question then is... how old is this transformer? If it's old enough, there may be a question of PCBs...
    EBEBRATT-Ed Member Posts: 20,484
    Could be the transformer but I doubt it
    . It would have quit by know.
    The burner and boiler are probably plugged up, back drafting or a fouled up firing head or end cone. You need a professional to look at this before the problem gets worse
    rick in Alaska
  • STEVEusaPA
    If you’re saying the whole housing has fuel oil in it, I think your fuel pump may be bad, seals leaking, or some other leak.
    If the transformer is smoking or 'smocking' as our president tweets, then that’s a different issue, then you shouldn’t run it at all.
    There’s no oil in a transformer. There is tar in there.
    Any reason why you haven’t had a competent tech come out to diagnose it?
    rick in Alaska
