Hot water baseboard system
JimGlose
JimGlose Member Posts: 3
Hot water baseboard system, 5 zones
In two of the zones, when the thermostat calls for heat, the valve opens, but the circulator doesn't come on.
Where is the problem?
    Jamie Hall Member Posts: 27,377
    Check all your wiring and the end switches on the valves for starters.
  • delta T
    delta T Member Posts: 884
    most likely bad end switches. Are these honeywell zone valves? depending on how old they are, you can most likely change out the head without draining any water.
  • JimGlose
    Thanks fellas!
