low water but not really (update)
Grallert
Grallert Member Posts: 1,037
My #1 boiler has been running for about fifty hours with not issues mentioned in my previous post. Seems I over dosed the poor old thing.
I drained the boiler and refilled with clean water, a half day task. I must have added too much chem when I put the boilers to bed in the spring,. I have no idea the affect it would have.
We use RMC OS-125 O2 scavenger and RMC BFW-504 Boiler corrosion and scale inhibitor. I'll fire the #2 boiler after the break. Now all I have to do is dial in the chem pump.
Thanks you guys for the input and ideas. I come the this sight to learn something every day.
  • And your experience can be a lesson for all of us on the dangers of over medication!—NBC
    Grallert
    Jamie Hall Member Posts: 26,838
    Good show. Easy enough to do, but a bear to fix! Did you ever do anything with that trap survey?
  • Grallert
    No other than find them all. The issues I was having around the time of your visit seem to have left campus. I don't recall what I did if anything to make that part of my life easier other than continue to get the pressure down. One boiler is still pushing 2psi and I know there is no need for that. Next service I'll have the tech lower the firing rate a tad I think. That's out of my wheel house.
