0-16 ozs or 0-4 lbs PSI vaporstats?
JohnNY
Member Posts: 3,226
Is there a compelling reason to choose either the 0-16 ozs or 0-4 lbs PSI vaporstats when you know darn well you'll only be using it for operating under 1 psi? I guess I'm asking for stocking reasons.
Installers and service techs, what drives your decision to purchase one to keep in stock?
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes
Classes
I stock the 0-16 oz vaporstat because I assume it would be more accurate?DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
I cannot force people to spend money, I can only suggest how to spend it wisely.......1 -
I use the 16 oz on Vapor systems, the 4 lb on anything else.New England SteamWorks
newenglandsteamworks.com-1 -
Both good answers. Thank you.New England SteamWorks said:I use the 16 oz on Vapor systems, the 4 lb on anything else.
Classes0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
