Boiler stops running after a few hours
kiemside
kiemside Member Posts: 10
It is a gas steam boiler with a wired-in thermostat.
Everyday, it always runs first time I turn it on. But it stops running after about 2 hours.
When it runs, I use a multimeter to check and find voltage at the thermostat and between terminals C and R and between terminals C and Y at the transformer.
When it stops running, there is no voltage at the thermostat and also nothing between terminals C and Y. However, there is still voltage between terminals C and R at the transformer.
The vent damper is on always on the "open" mode.
Does anyone know what is going on?
  • JUGHNE
    JUGHNE Member Posts: 11,634
    Does your pressure switch shut it off?
    If so it should start again if the T-stat is still calling for heat.
    Jamie Hall Member Posts: 27,750
    Or any one of several other safeties -- like a low water cutoff?
  • kiemside
    I found the culprit. It was the pressuretrol and its pigtail pipe, which were clogged. I open them up and cleaned them. Put them back together and the boiler was running all night.
    I guess because of the deposit inside the pressuretrol and the pigtail pipe, the pressure never got back down to the cut-in pressure. As the result, the boiler doesn't turn back on after running for a few hours.
