Air bleeder screw on CI rad
Fred Rappuhn
Fred Rappuhn Member Posts: 107
When install cast iron standing rad's, does the air bleeder screw go on the return side of the rad. ? Or does it matter?
    Jamie Hall Member Posts: 26,842
    Doesn't really matter for hot water. When you're bleeding the radiator, the water will come up to the level of the bleeder on both sides.
    Fred Rappuhn
