Weld 8” leaking joint?
Timco
Timco Member Posts: 3,040
Piped together a 800k steamer 2 years ago. Now there’s a pretty good leak at a 8” threaded joint. Is there any chance I can just weld this joint? Really can’t unthread it.
    Jamie Hall Member Posts: 25,713
    I couldn't -- but I'll bet you can. Just remember that if you do, it surely isn't going to come apart again...
    1Matthias
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,577
    What sort of pressure is this getting up to for it to leak?—NBC
  • 1Matthias
    1Matthias Member Posts: 148
    Not without a grinder and a whole lot of patience...
  • Timco
    2psi.
  • Solid_Fuel_Man
    I'd weld it. Be sure the fitting is steel and not cast. You can tell by the sparks that come from grinding a bit of it. Steel makes big sparks and iron makes small sparks.
  • Solid_Fuel_Man
    But for that matter, with very low pressure you can probably get away with MIGing the cast.....just dont tell anyone.....😁
    1Matthias
  • Henry
    Henry Member Posts: 998
    That is the reason that we weld anything from 2 1/2 inches.
    Jack
  • Timco
    Soooooo...wanna guess why it was leaking? They filled the steam system up to the 4th floor....
    Solid_Fuel_Man
    that'll do it...
    Those wet returns will be nice and clean after draining that water out!—NBC
  • Solid_Fuel_Man
    Oh! They thought it was a gravity water system!
    1Matthias
  • JUGHNE
    JUGHNE Member Posts: 11,358
    That would have tested your pipe hangers!
  • BenDplumber
    BenDplumber Member Posts: 50
    Grind/clean e6010 root pass e7018 fill & cap. Gentlemen we are professional. 8" steam piping?? Please call a pipefitter/welder for repair.
