Selecting flat panel radiator - 17-inches wide 4500 btu or so
Steve Garson_2
Member Posts: 712
I need to squeeze a 4500 btu radiator onto a wall that is only 17-inches wide, including valves.
Can anyone recommend a brand that will work for this application?
Steve
Steve
Steve from Denver, CO
You might look into these.
https://runtalnorthamerica.com/residential_radiators/pdf/PBColumn.pdf"If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
Only Runtal has column radiators that can be custom ordered for output. Common steel WPR start at 24" wide (Buderus, DiaNorm). Wait time is 4-6 weeks
- 120 Geothermal
- 394 Solar
