Building heating management system
DavidMarasow
Member Posts: 16
Anyone recommend a BMS for a multi family.
I don’t want a simple heat timer that controls the boiler based on a timer and a algorithm....
I want a system that can use data from current temps inside units, and outside temps that can
A- turn on and off the boiler only when needed to achieve max savings.
B- control what temps to heat the water as to get maximum savings (condensing .....the boiler when needed)
C- calculate when the boiler should go on based on future weather incoming temps.. ie if it still going to be colder maybe raise the temps a bit to keep run times down...
D- keep all this data online and accessible via smartphone....
What type of system?? Water?? Steam??0
Water0
You're still only asking for a boiler controller, not necessarily a BMS. I know what you said, but the Heat-Timer MPC, with multiple wireless sensors, does all that.
Aside from that, Tekmar is probably your best bet. Are you in NYC?Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes0
- 125 Chimneys & Flues
