EZEWARM
KeenGreen
Member Posts: 27
This will probably a really simple answer for my question, but here it goes.
I have a customer that is using a EZEWARM heating mat in their bathroom(under the tiles of course)
And their thermostat is not working. Can i simply replace it with a Honeywell thermostat or does it need to be brand specific?
I am not doing the install, i am just trying to find something that will work.
KeenGreen
KeenGreen
Step one is going to be to check and see if the thermostat is line voltage and controlling the full load of the mat. If so, you are going to need a line voltage thermostat with that rating. Not that they are hard to find...Br. Jamie, osb
- 120 Geothermal
- 394 Solar
