failed closed steam trap
gerry gill
Member Posts: 3,078
couple of pictures in case anyone hasn't seen a failed closed steam trap from its outset side.
gwgillplumbingandheating.com
-1
Thanks, Gerry. Failed-closed is so much nicer than failed-open.Retired and loving it.0
Is that a vertical Trane B-1?All Steamed Up, Inc.
https://heatinghelp.com/find-a-contractor/detail/all-steamed-up-inc0 -
yes sirGordo said:Is that a vertical Trane B-1?
Serving Cleveland's eastern suburbs from Cleveland Heights down to Cuyahoga Falls.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
