failed closed steam trap
gerry gill
Member Posts: 3,078
couple of pictures in case anyone hasn't seen a failed closed steam trap from its outset side.
gwgillplumbingandheating.com
-1
Thanks, Gerry. Failed-closed is so much nicer than failed-open.Retired and loving it.0
Is that a vertical Trane B-1?All Steamed Up, Inc.
https://heatinghelp.com/find-a-contractor/detail/all-steamed-up-inc0 -
yes sirGordo said:Is that a vertical Trane B-1?
Serving Cleveland's eastern suburbs from Cleveland Heights down to Cuyahoga Falls.0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
