How to adjust flow?
Hello all,
I recently purchased a 20yr old home with infloor radiant (hw) heat. One zone includes the bedroom and the bathroom. I’d like to decrease the flow to the bedroom. See the attached pic of the valve on the manifold. I’m not familiar with it; can anyone tell me how to adjust the flow? I’m not sure if it’s like a tap that needs multiple turns, or if a 90 degree rotation will do the trick. Anyone familiar with this? Any help is very appreciated!
    hot_rod Member Posts: 27,026
    it looks like a mini ball valve with a slot for adjusting. Hard to know for sure without looking inside.
    If it doesn't turn easily, consider replacing it with a better balancing valve, or flow setter with window to read gpm.
    gordonbone
  • Ironman
    Ironman Member Posts: 7,885
    Why do you need to reduce flow?
    Bob Boan
  • gordonbone
    gordonbone Member Posts: 3
    If it’s a ball valve, should a 90 degree rotation be full on or off?
    The reason I want to reduce the flow is that the room it serves is getting too warm, but there are other rooms in the same zone that are not warm enough. (I don’t think the zones were well thought-out)
    ball valves are usually 1/4 turn. When the handle is inline with the valve it should be full open. Crosswise handle should be full off.
  • Ironman
    Can you post some pics from a little farther back that show the entire piping arrangement?
    Bob Boan
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,578
    edited September 2018
    Check and see whether your thermostat is configured for hot water heat. That setting can have a big impact on comfort levels. Is there an outdoor reset function in the system?
    Are you using any temperature setbacks in this infloor radiant system.
    Any flow change in any of the loops is bound to have some effects in the other loops, which is why the use of a flow setter, with flow metering dials is recommended.—NBC
    gordonbone
