pressure test
I had the boiler piped to the header and back to the boiler with inch and a quarter threaded pipe and pressure tested it and did not see any bubbles, I did lose about 1 psi per hour. I used dawn dish soap 50/50 water and soap on every threaded joint. There is a hydraulic separater in the system if that makes any difference. Anybody have any suggestions?
What pressure did you use?Bob Boan
The pressure dropped all the way to zero. over a 12 hour period.hot rod said:Does it go to 0 psi, or drop a few lbs and stop?
Air from a compressor is hot, when it cools it may show a few psi drop.
Any gasket connections? those sometimes need to get wet to seal air tight.
The cap on all air vents tight?
The gaskets on the hydraulic separator leaked but they were tightened up and no longer appear to be leaking. The vent at the top of that is tight.
Unless those gaskets are a real slow leak.0 -
You might remove the green gaskets from the Sep and soak them in water for a few minutes and reinstall, this seems to help them seal better. If you want to try the air test again, 25- 26 psi is fine and will show an air leak better.
If all the piping work you have done is visible, and in the mech room, then water will surely show the leaks.Bob "hot rod" Rohr
Living the hydronic dream0 -
Agree with all the above, I would use a proper leak locating solution too. I have used 50/50 soap before and it does work, but I have found very slow leaks much better with real leak locating solution because it will leave thin film that will still show bubbles many hours after application, soap and water will dry out and it does not seem to leave a good film.
I found a very slow leak on the seam of a ball valve one time that didn't show up until the next day, when I came back to discover a golf ball sized clump of bubbles on the ball valve. stayed there for 2 hours the day of application and never saw anything, only saw it when I came back the next morning.0 -
Any unions? .... check them first.0
Delta T what is a leak locating solution?delta T said:Agree with all the above, I would use a proper leak locating solution too. I have used 50/50 soap before and it does work, but I have found very slow leaks much better with real leak locating solution because it will leave thin film that will still show bubbles many hours after application, soap and water will dry out and it does not seem to leave a good film.
All piping is visible, I will bump up the pressure. As for taking the seperater gaskets out and soaking them, there is also the boiler protection valve and the 4 quick setters. Those gaskets don't seem to like to be taken out too often.hot rod said:You might remove the green gaskets from the Sep and soak them in water for a few minutes and reinstall, this seems to help them seal better. If you want to try the air test again, 25- 26 psi is fine and will show an air leak better.
If all the piping work you have done is visible, and in the mech room, then water will surely show the leaks.0 -
I've had pressure relief valves not hold air, but hold water just fine.Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0
Right now I have no pressure relief plumbed on, that will be the next step.Solid_Fuel_Man said:I've had pressure relief valves not hold air, but hold water just fine.
Hot Rod I bumped up the pressure and now I see bobbles at the header joints at the seperator. The connections on that seperator are very hard to get at. What do you think fill it with water and see if they seal. Or take it apart and soak for awhile. All the smaller green gaskets seem to hold.hot rod said:You might remove the green gaskets from the Sep and soak them in water for a few minutes and reinstall, this seems to help them seal better. If you want to try the air test again, 25- 26 psi is fine and will show an air leak better.
Fill it with water, those gaskets usually seal when they get wet, give them a crank if you can get a big slip joint pliers or wrench once they get wet, if you can.
Assuming they are aligned without any sideways stress on the unions?Bob "hot rod" Rohr
Hot Rod I actually took them apart and soaked the gaskets for 10 minutes put it back together and 2 of the leaks stopped the last one was very small and has now stopped since I filled the system with water. Actually all of the leaks at the seperator were very small. My main leak was a reducing bushing that is in a very hard to get at spot. I forgot to tighten it up, it was a little tighter than hand tight. It looks like I am good now. Thanks for your suggestions1
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
