Proper nozzle?
georgede54
georgede54 Member Posts: 55
edited August 2018 in Oil Heating
I have a Burnham boiler Model # PV8 5 ST HBUR.
Does anyone out there know what is the proper nozzle for use with that model?
Thanks.
George
    Steamhead Member Posts: 18,500
    What burner is on it?
    Consulting
    georgede54
  • georgede54
    Thank you for getting back to me.
    Other than by giving you the model number, I'm not sure how to tell what burner it is on.
    How would I find out?
    Thanks,
    George
  • GBart
    GBart Member Posts: 746
    The installation manual will tell you but it doesn't sound like you should be attempting to replace this yourself. You need to be trained to service our equipment or you can burn your house down and cause serious injury or death.
    georgede54
  • STEVEusaPA
    Post a picture of the burner.
    As @GBart alluded, there's a lot more to safely running your burner than just changing the nozzle. The first one being that you also need to know the fuel pump pressure.
    georgede54
    And, after doing any work on a burner it must be tested with a digital combustion analyzer. This is a safety issue.
    If your present service company is not testing the burner, they do not deserve your business.
    Consulting
    Canucker1MatthiasGBartgeorgede54
  • georgede54
    Thanks one and all. I was never considering replacing it myself. But I think it's all been straightened out.
