Drawing Software you use.
RayWohlfarth
RayWohlfarth Member Posts: 1,912
I was wondering what software you use for drawing or sketches. I tried using Cad and its way above my pay grade. I have used Smart Draw and Edraw and curious what you use. I have a Mac
Ray
Ray Wohlfarth
Boiler Lessons
  • ScottSecor
    ScottSecor Member Posts: 1,021
    I use Taco HSS and have been for years. I also use Loopcad on occasion. Neither of them are al that easy now that they added so many features. Takes me a little while get used to the what appear to be constant 'upgrades.' There may be better software out there, but I'm pretty comfortable with both of these for now.
  • RayWohlfarth
    thanks Scott
    Ray Wohlfarth
    Boiler Lessons
    hot_rod Member Posts: 26,895
    Here is one you might try out, Siggy and Mario developed it.
    It's web based so you just sign in to access it, no need to update, or have it run on your machine, a yearly fee gets you access.
    Very easy to use, drag and drop the components, connect with any color lines. Although I'm far from a pro on drawing programs.
    It seems to run best on Google Chrome, I had some issues running it on Safari.
    I think there is still a free 30 day demo at www.hydrosketch.com
    EBEBRATT-Ed Member Posts: 19,791
    I use Visio. Never used anything else so I can't compare it to anything. probably not the best choice but I have done some decent stuff with it.
  • RayWohlfarth
    Thanks @hot rod and @EBEBRATT-Ed I appreciate it
    Ray Wohlfarth
    Boiler Lessons
  • Wellness
    Wellness Member Posts: 154
    edited August 2018
    Like @EBEBRATT-Ed , I use Microsoft Visio, although I previously have tried Smart Draw. But after I figured out that all you are really doing with these programs is drawing lines to an image of a pump, valve or other device, Visio (and Googling HVAC device images to paste into the drawing) made the most sense to me.
    Caleffi has a bunch of free stencils also, they work in Visio and other programs. We keep adding to, and updating the library.
    Rich_49
  • Mike_Sheppard
    Mike_Sheppard Member Posts: 698
    edited August 2018
    Been looking for something like this! I'm going to try that Caleffi one. Thanks @hot rod
    I''ve tried a few different ones and even though I consider myself pretty computer and tech savvy they all seemed like way too much to figure out.
    I'm also looking for something that can do 3D piping too. I think it was @nicholas bonham-carter who posted a 3D picture of a new steam boiler he was installing. I was wondering what program that was; it looked very good.
    EDIT: It was actually @New England SteamWorks who posted the 3D piping picture, not Nicholas. Sorry.
    Never stop learning.
  • Harvey Ramer
    Harvey Ramer Member Posts: 2,281
    I use Visio a lot. Easy fun and fast. I downloaded Caleffi, Watts and Tekmar stencils. Between those three, you have most of everything covered.
    Here is the drawing for a design I did not long ago.
    @Harvey Ramer , @hot rod , @Wellness . Thanks for the Visio info on stencils etc. Never been able to find any. Now I know where to look.
    I usually draw stuff at home and e-mail it to others in our shop. Of course they don't have Visio. So I convert Visio to a PDF and send that.
    I am not very computer savvy but I get by somehow.
  • GroundUp
    GroundUp Member Posts: 2,475
    I tried Smart Draw and Hydro Sketch, hated them both and went back to the old reliable pencil and isometric paper. I'm definitely not tech savvy which plays a role I'm sure, and I'm the only one who needs to read my drawings so it's 10x faster and easier for me to do it on paper
  • Wellness
    @EBEBRATT-Ed. One tip is that when you Google HVAC product images, look for small or medium sized ones with white or transparent backgrounds that will blend into your drawing. Then, just right mouse click on the image and choose "Save Image As..." Make a note of where you saved the image on your PC, then open up Visio and browse to that image and insert it into your Visio drawing.
  • TheKeymaster
    TheKeymaster Member Posts: 36
    I'm a cad monkey that comes here for my hvac questions and just to waste time learning stuff on my down time at work. I don't use it at my work but I've used it in the past. Autocad Plant 3D is a pretty nice program. You can get a free trial at autodesks site. It figures most things out for you. Shows you the flows and when it is restricted by pieces you ad in. Add a part lets say a T into a line and it auto cuts the line and adds the T. Pretty slick.
  • Leonard
    Leonard Member Posts: 903
    edited August 2018
    Been a long time since I used CAD at work, but what I loved about it was I didn't have to spend time scaling the drawing. Put in the dimensions of everything and it would scale all the parts in proportion so the part looked like it would be when made.
    Mechanical Eng
  • RayWohlfarth
    Thanks for all the info. I have tried Cad and it never seemed to click with me. I have tried Visio and switched to Edraw when I got my Mac.
    Ray Wohlfarth
    Boiler Lessons
  • nacionaluno
    nacionaluno Member Posts: 1
    I used Visio. Here examples
  • ChrisJ
    ChrisJ Member Posts: 17,108
    I use AutoCAD 2022 and Fusion360.
