Prefab
Harvey Ramer
Harvey Ramer Member Posts: 2,261
3 zones with indirect ready to go in on monday.
Prefabbing in the shop is fun and efficient.
Steve MinnichSolid_Fuel_ManZmanNY_Rob
  • Snowmelt
    Snowmelt Member Posts: 1,428
    Nice, who’s indirect heater is that?
    Harvey Ramer
  • Steve Minnich
    Steve Minnich Member Posts: 2,868
    Very nice, Harvey! Another boiler guy who can bend conduit!!
    Steve Minnich
    Harvey Ramer
  • Steve Minnich
    @Snowmelt - Triangle Tube, same as boiler.
    Steve Minnich
  • Robert O'Brien
    Robert O'Brien Member Posts: 3,568
    edited August 2018
    Nice! Only way to fly!
    Harvey Ramer
  • Solid_Fuel_Man
    I like your clean zone valve arrangement Harvey. And I too noticed the bit of EMT, always cleans up wires as far as I'm concerned.
    How do you like the Caleffi zone control? I've used Taco exclusively so far. How do they compare?
    Harvey Ramer
    hot_rod Member Posts: 24,652
    real nice, clean, layout. The owners should be delighted.
    Harvey Ramer
  • DZoro
    DZoro Member Posts: 1,048
    Very nice, I too have been prefabbing. Are you removing the boiler from the board when delivering and taking into the jobsite? Then re installing the boiler?
    D
    Harvey Ramer
  • NY_Rob
    NY_Rob Member Posts: 1,370
    The homeowners don't know how lucky they are to have you on the job Harvey (and Robert)!
    Have you had good results with the Saniflo SaniCONDENS Condensate Pump?
    I have one waiting to install but the reviews here were mixed so I haven't taken it out of the box yet. I'm still using the gravity fed neutralizer tube which is a pain to service vs. a the pull-out tray on the Saniflo pump.
    Harvey Ramer
  • Harvey Ramer
    Thanks! I don't do it often enough to be very good at it. The one piece has 4 bends in it. I screwed up on my first attempt.
    It does help clean things up.
  • Harvey Ramer
    They are both good controls, as far as I'm concerned. The caleffi does have more space for wiring, which I like.
  • Harvey Ramer
    > D
    Correct. All the piping has unions. The wiring harness remains coiled in the boiler to be connected to the j-box after the boiler is hung.
  • Harvey Ramer
    I like the saniflow and have had no problems with it. It's a great space saver and easy service.
  • NY_Rob
    ^ thanks Harvey... guess I'll install mine then :)
