carbon ceramic seal B&G 100 series
I had a very small water drip coming out of my B&G circulator, 100 series. I took the pump apart and the mechanical seal was only a carbon disc turning against a cast iron face. I was expecting a ceramic disc to mate with the carbon. I hesitate to repair using only the carbon piece that I would think not "seal" against the cast iron face that certainly doesn't have a mirror like finish. How common is this?
    HVACNUT Member Posts: 7,233
    So common you should throw it in the scrap heap and get yourself a wet rotor circ.
    The B&G 100 has been around a long long time and they do offer a replacement bearing assembly if your just looking to tinker. Replace the coupling while your in there.
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,686
    It needs the ceramic ring to work.
    Retired and loving it.
    pecmsg Member Posts: 6,781
    and the rubber feet that hold the motor in line
  • Pumpguy
    Pumpguy Member Posts: 781
    edited July 2018
    While a ceramic is the most common type of stationary component of a mechanical shaft seal, at least IME, NiResist is also used. NiResist looks for all the world like cast iron, but it is a legitimate shaft seal component material.
    In addition to ceramic and NiResist, Tungsten carbide and silicon carbide are used too.
    For me, given the choice for normal heating applications, I would go with the ceramic. For high temperature applications, TC or SC are frequently used.
    When changing a mechanical shaft seal, both the rotary carbon and the stationary element should be replaced together.
    Hope this answer is helpful.
  • unclejohn
    unclejohn Member Posts: 1,833
    All you need is the bearing assembly. Any supply house.
