Taco model number question
PeterSim
Member Posts: 1
hello everyone,
My air conditioner relies on a Taco water pump to circulate hot water for heat. The old one on my AC is no longer being produced. I found the new model as 006-BC7-5IFC. However, 006-BC7-5IFC is hard to find but 006-BC7-IFC is easier to get.
A local contactor told me 006-BC7-5IFC and 006-BC7-IFC are interchangeable. It is just difference in generations. Is this true? Thank you.
Peter
Peter
Can you explain better or post some pics? A/C needs a circulator for heat?
A Taco 006 is a bronze or stainless circ typically used for domestic water.0 -
PeterSim said:
hello everyone,
Peter"If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
If your needing a circulator to pump hot water to a coil in the duct I wouldn't be too concerned about replacing with the exact same model.
A 0015 taco is a 3 speed so you can fine tune to the flow you need. Probably low speed?
Same for a 15-58 Grundfos.
Both more common than 006.
My 2¢.0 -
The 006-BC7-5IFC has a 24 volt relay (and larger control box) for First Company air handlers (to exercise the pump, meeting local codes) so it's probably best to replace same with same. NOTE: If you are looking at any other model or brand, the 006 is bronze - if replaced with cast iron there may be rust issues.
Both are still available...2 -
It needs to be a low lead alloy circulator if it touches potable water. I think most DHW circulators are now stainless, not bronze.Bob "hot rod" Rohr
Living the hydronic dream0 -
Ok, my bad. Didn't consider circulating potable water for heat.0
Stainless, low lead bronze, plastic - whatever as long as it's a non-ferrous material that will not rust with excess air in the water (like open DHW systems). Also must comply with NSF etc (low lead compliant) if used in drinking water applications...0
- 125 Chimneys & Flues
