Hands In Pockets, Please
HeatingHelp
Have you ever found yourself in some dank basement staring at (and totally appreciating!) the simple beauty of some old one-pipe, gravity-return steam heating system? And then you decide that this system, which has gotten by without you for nearly a century, should have motorized zone valves. Know that you are doomed on the day that you make this fateful decision. Doomed, doomed, doomed! And here's why.
Way back when Uncle was paying me, I had a Master Sergeant on whose wall was a big poster: KISS! Good advice...Br. Jamie, osb
Bravo,
Leaving at least one hand in your pocket is also valid when working on high voltage to avoid completing the circuit and knocking you across the room.0
- 87.8K THE MAIN WALL
- 131 Chimneys & Flues
