Millivolt LP Gas Valve
dennya
Member Posts: 13
in Gas Heating
in conjunction with proper millivolts, do we also need a minimum LP gas pressure to make the main valve open?
if so, what is that minimum pressure?
All LP systems off the second stage regulator send 10" W.C. pressure to the gas valve. That is the requirement. Why are you having a problem?0
- 128 Chimneys & Flues
