Tran TWE031E-SF-1B Not running except for fan mode only
I have a Tran TWE031E-SF-1B the fan runs in fan on mode but will not run in heat or AC mode. I replaced the ICM but it did not resolve the issue. Can it be the motor control board or something else?
  • ratio
    ratio Member Posts: 4,264
    Did it just stop working, or did something change, like a new thermostat?
    If you leave the fan in the on position does the system work, i.e. heat & cool properly?
  • the_donut
    the_donut Member Posts: 374
    I’ve seen that issue with part of a relay being fried on a simpler system. Not familiar with that model though.
