Thermostat can't activate shared pump to boiler
Alex488
Member Posts: 1
So I got an ecobee thermostat in one zone and a regular old school thermostat in another zone. They share the same return pump to boiler. For whatever reason, the ecobee stopped being able to activate the pump. When I turned temp up on conventional thermostat, everything was fine including green light on relay board turned solid green, pump starts, heat comes. When I turned temp up on ecobee, the green light on relay board flickered but didn't go on, no pump, no heat. For me to get heat in zone controlled by ecobee, I have to turn temp way up in the other zone so the pump is running. Does anyone know what issue I am dealing with? Btw, it's been having this issues on and off recently
Does each thermostat open a zone valve? You may have a bad end switch on the zone with the. Ecobee.0
Insufficient data to make a analysis. Maybe the ecobee thermostat need a jumper between the R & RH. Did it work before and you are now experiencing problems or is it a new addition?0
Batteries in the Ecobee?Br. Jamie, osb
Is the Ecobee 24v powered or just R-W? You might need a common or a resistor.0
