moving floor radiator copper pipes to remodel a room
May i ask if the kitchen wall radiant copper heat pipe can be moved from the base of the floor to under the 3" kick plate of the base kitchen cabinet? I want to add kitchen cabinets to the existing room but the floor copper radiant boiler heat pipe runs along the entire wall. can it be rerouted?
    Jamie Hall Member Posts: 27,579
    What exactly is meant by a radiant copper heat pipe? Is this the pipe feeding a radiant panel? Or is it itself the radiant heat source?
    Usually when I think of "radiant" I'm visualizing a pipe buried in a floor or wall, warming the surface...
