Replacement bulb needed for air purifier
zepfan
zepfan Member Posts: 471
I am trying ,with no luck to find for a customer a replacement bulb for an Airazor ultra violet air purifier model# UVL-36w. I have looked up the company on line, and can't them nor a distributor. The product is made by Bell Air UV systems LLC. I have not been able to locate them, and the phone number that is on the unit is no longer in service.It may be time for the customer to buy a new unit. Thanks to all.
    Jamie Hall Member Posts: 27,680
    That's a UV bulb. Is there any number on the bulb base? There are a number of sources for UV bulbs; they come in a host of different shapes, wattages, and particularly base configurations, but if you can match that you can find the buib. Google "UV bulbs"
    zepfan
    Try here -- they have a huge variety, oddly enough.
    https://www.thepondguy.com/category/uv-bulbs-by-watt
    zepfan
  • zepfan
    Thank you so much, it actually looks like they may have a replacement bulb. take care.
  • BillW
    BillW Member Posts: 198
    Do you have a "Batteries and Bulbs" store near you? They may have it, or at least will be able to get it for you.
