Steam Vent Replacement
stevie27
Member Posts: 10
I recently moved into a house with a steam boiler and original radiators on a one pipe system. After doing som research, I believe the steam vents need to be replaced.
All of the rooms are currently fitted with Hoffman 40's. (https://www.amazon.com/Hoffman-Steam-Angle-Radiator-401440/dp/B0057XTJOI). I have read that different radiator locations require different sized vents. Should I replace all of these, even if they're fully functioning?
I have a radiator on the second floor with a broken valve that does not work at all. It's a large room(converted attic). Which size should I buy for this?
On one of my radiators, the steam vent is about 45 degrees off from vertical, but it won't go vertical without considerable loosening. Suggestions for how to fix this?
On one of my radiators, the steam vent is about 45 degrees off from vertical, but it won't go vertical without considerable loosening. Suggestions for how to fix this?0
There are actually 2 radiators with a 45 degree vent. They both work, but one is spitting out a lot of water, so I will definitely replace that one. The other one only heats 1/3 of the way, but I'm guessing that's more of an angle issue for how it sits?0
Make sure the radiators have a little pitch, back towards the pipe. If they are level or pitched the wrong way, they will hold water and the vents will spit or the steam will condense in the radiator before it get all the way across to fully heat the radiator.0
that 45* vent,
is it loose that you can easily back it out and you have it at 45 to be tight?
take it out and add a couple wraps of teflon tape and snug it back in to 90.
keep the tape back one thread from the nipple end so as not to get it in the vent.
they really should be closer to 90 vertical.known to beat dead horses0
