23 yr old Lochinvar doesn't like to heat home in severely cold temperatures
Chen1261
Member Posts: 1
Did a 1993 lochinvar hot water baseboard boiler system require a main loop? We have obvious condensation problems that may have affected the 'heat exchanger'? I think that's what they called it? Is the cost to have that exchanger cleaned worth the it - 600.00 to 1000.00? Or would it be wiser to purchase a new furnace? It seems to run fine but cycles often and the CO exhaust is high but going up the chimney. Should I have a main loop installed to help eliminate condensation concerns? We are likely moving into new home construction this year and I don't know if the investment is worth the time and dollars?
Going to need more details. Some pictures would help.
The site has a no pricing discussion policy so avoid that please."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
I assume this is a fin tube boiler? If the heat exchanger is badly corroded, it should be cleaned, but......at 25 years old you are close to the expected life span. Need more info on your system to tell you if it is piped correctly or not. Any non-condesing boiler should have low temp protection of some kind.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
